NH 461 haybine parts needed
NHBalerman
11-14-2006 19:29:28
Has anybody got a junked out NH 461 haybine? I need the tension spring and the cables and the handle that holds tension on the rollers. Is there any salvage yards that might have one? Not any of them used down here in my neck of the woods. Thanks
Eugene SWIA
11-16-2006 17:11:31
 Re: NH 461 haybine parts needed in reply to NHBalerman, 11-14-2006 19:29:28
I have a 460 we could take parts off of. I'll look it over this weekend. Gene
NHBalerman
11-16-2006 18:13:53
 Re: NH 461 haybine parts needed in reply to Eugene SWIA, 11-16-2006 17:11:31
Thanks and let me know if you have it.
Eugene SWIA
11-22-2006 03:50:03
 Re: NH 461 haybine parts needed in reply to NHBalerman, 11-16-2006 18:13:53
Sorry I didn't get back to you sooner. The whole assembly is there. What all do you need? This is a 460. I think they should the same. Gene
NHBalerman
11-15-2006 19:41:26
Marv, do you remember the length that you made your cables? I tried to make some cables and I can't get the cable clamp tight enough to hold it. Thanks
BigMarv1085
11-15-2006 05:56:20
I made my cable out of small piece of 3/8 cable. NH Part # is 127666 ctr. cable, and the cable on the rt.side is NH 127676. My old 461 had 2 springs that came off just forward of the inner wheel bearings. Had to adjust tension with a big wrench instead of a handle.
