JD A Oil Maintenance
Corey G
11-11-2006 19:44:24
I recently got a 1947 John Deere Model A. How much oil is needed for the transmission, hydraulics, and motor?
2t2@ia
11-12-2006 19:24:30
 Re: JD A Oil Maintenance in reply to Corey G, 11-11-2006 19:44:24
Hydraulics are not interconnected with the transmission. Think they take about a gallon of oil. Originally common motor oil was used. Suppose 303 would work O.K.
Butch ( PA )
11-12-2006 00:53:34
The transmission and hydraulics are all interconnected. I just changed mine and it takes 27 quarts of either 90 wt oil or I put in 140 wt. oil ( but I don"t plan on using it during the winter.) The heavieer oils help seal the places where it may leak around the axles etc. The crankcase engine oil takes11 quarts of 30 wt. oil, again I put in different wt oil because I replaced the rings etc. Hope this helps you. Have a great day.
Butch
