Last Chapter on JD VB Grain Drill...
Baggsy
02-23-2000 06:43:23
Got ahold of JD dealer last thursday and low and behold, they still make the adjustable feed cup gates that I so sorely needed. Old ones were THOROUGHLY rusted in, lip on outside edge where routine cleaning of the inside didn't touch. Needed to get penetrating oil in there! Thought about Gerald J's suggestion of taking the seed box off, but decided to try it 'in situ'. Managed to get the lip peeled back on the first on with a pair of wire cutters. It was floppy and couldn't stay square with it using a chisel. The old ones on there had a pin that was flared in the middle to stay tight on the gate. It didn't appear to want to come out of the hole in the feed cup, so I worked it out thru the front. The last two I managed to get at the pin using a small chisel and a real high tech tool I found locally...a nail! All three had the flared center pin. Monday morning was out wire-brushing the openings and here came the UPS truck with my parts! New gates seems substantially heavier than the old ones. New ones have a straight pin but the gates are crimped in two places to hold the pin in place, and I do mean crimped. Tryed to drive the pin in place but couldn't get enough swing to punch the pin very hard. Removed it out the front with the pin stuck, and then stuck my punch in it getting the pin out. Then I stuck my nail in it getting the punch out. They are TIGHT. Ended up driving them all down flush with the bottom edge then working them in from the front. Now she's in good shape. I also ordered a metal seeding chart for the drill. It's for models B, FB, LL, LZ, PD, and EE drills, and even has settings for Kaffir Corn, which I had to go look up. Thirty dollars worth of parts and I'm in business...hooked her up and pulled it around a little bit, and it doesn't even squeak! Now I gotta order some seed...
