Replacing wagon spindle
IA Farmer
11-10-2006 20:07:43
I'm looking for suggestions on which welding rod to use on the rear spindle of a 12 ton running gear. It is 2 1/4 in. in diameter and doesn't appear to be hardened. 6013, 7018 or something else? Thanks.
hayray
11-11-2006 03:20:49
 Re: Replacing wagon spindle in reply to IA Farmer, 11-10-2006 20:07:43
I used some 7018 on the last one I just did, it worked ok.
Don-Wi
11-10-2006 22:44:06
I think 7018 would be a good choice. I've done a few at a machine shop I used to work at, but those we welded back in with a wire feed. I'm guessing it was overloaded and the spindle bent a little? Normal cause on the ones we did....
Donovan from Wisconsin
