New Holland Baler
Donald Scott
11-08-2006 18:08:06
Does anyone know what a New Holland super 77 baler weighs?
Jon Holt
11-12-2006 19:36:20
 Re: New Holland Baler in reply to Donald Scott, 11-08-2006 18:08:06
I bought an IH baler this summer and towed it from mid southern Missouri to NE Kansas. Took the state highways and enjoyed the countryside. Took our time and only had one problem, one tire blew out on us. I had taken spares so it was no problem at all, just changed tires and off we went.
Josh in Pa
11-09-2006 05:52:28
I scrapped one with a wisconsin engine on it, and it wieghed 4500 lbs.
Josh
mn.Chuck
11-09-2006 05:21:33
Donald, From the owners manual: PTO 4400, Engine
4550.
FreeRanger
11-08-2006 21:23:48
Too much for that trailer you have in mind! If you have to ask yourself "can I do this?" Then maybe you shouldn't?
Anyway, I have no idea but my NH 66 could not be lifted with cheap ATV jackstand. I think maybe 2,000#. Purchased quality 3ton floor jack and now can change tires.
My father has a New Holland 67 baler waiting to be transported from Northern IL to Southern WI. At this point we don't have access to a big enough trailer to haul on. So may pull at 30mph for 6 to 8 hours. It's 2 hour drive at highway speeds.
When should I pull it?
FreeRanger
11-09-2006 11:04:03
 Re: New Holland Baler in reply to FreeRanger, 11-08-2006 21:23:48
Repacking the bearings is what is keeping us from pulling so far. I just don't have the time to work on it in IL. I also don't have the space in my barn to store 2 balers.
Technically my father purchased the NH 67 baler at auction for my brother-in-law's birthday gift three years ago. However, brother-in-law lives inside city limits and has no land (or tractor). Baler is stored at his father's farm. They have been renting out the crop land for years and have no equipment anymore. Brother-in-laws parents are not in good health either. Many children so chances are brother-in-law will not get the farm. He's less mechanically inclined then me so he's not motivated to re-pack the wheels. I should practice on my NH 66 baler this winter.
I should just schedule some quality time with my father and get it done. He's the only one of us that is mechanically inclined. However Parkinson's is slowing him way down. Do you think if we have the correct tools and parts, can we repack both side in the morning and hit the road by the afternoon?
I will pull it with 2005 Crew-cab Chevy 1500 Siverado Z71 4x4. Loaded with floor jack, air compressor and hand tools. I going from south of DeKalb IL to north of Monroe WI.
KEH
11-09-2006 15:25:07
 Re: New Holland Baler in reply to FreeRanger, 11-09-2006 11:04:03
Freeranger,
I had a NH 67. It had bushings in the wheels instead of bearings and would not pull over 15 MPH without the hub on the heavy side heating up. I welded a car spindle to a steel rod of appropriate size and bolted it in.(You can tell what I'm talking about when you look under the baler at the axles) I think some 67s had bearings so maybe you will be lucky. If you try to pull it be sure and take a full grease gun.
I also had a NH 77. The other posts were right about the 4500 pounds.
KEH
Jimmy King
11-09-2006 09:00:50
If you pull it pack the wheel bearing first.
RodInNS
11-09-2006 08:10:37
If you've got enough truck in front of the baler, check the tires and teh wheel bearings, and go. I wouldn't hesitate to tow it at 65 mph either. I move my old baler around with my Ranger, on the back roads, at 50 mph... It handles fine as far as I'm concerned.
Rod
Ken Hull
11-08-2006 20:04:03
If it helps you get a rough idea, my New Holland 425 weighs 4,432 lbs.
