3309 IH/CASE ROTARY HAY CUTTER
KEVIN MCCULLOCH
11-06-2006 18:34:33
I was cutting some Johnson grass last Friday and one of my blades stopped turning. I took the hub off and inspeced the gears and they all appeared to be in good shape. The driver shaft gear needs to be moved over and I'm not sure how to get the shaft out to put a thrust bearing (or something) to move it over. Also I was told that there should be oil in the blade assemblies and there is not any. How do you get oil in each of them?
