Need a Pitman arm pattern.
mud
11-05-2006 06:07:31
We need a Pitman arm pattern for a McCormick Deering 27V sickle bar mower.
Can't seem to locate one.
Got plenty of wood, just don't have a pettern.
We have both ends of the pitman, but don't know the overall length.
Thanks -
mud
K-Mo
11-06-2006 04:42:20
 Re: Need a Pitman arm pattern. in reply to mud, 11-05-2006 06:07:31
Try Tractor Supply SKU 12-06413 $10.99.
K-mo
BCnT
11-06-2006 03:52:52
if you cant get specs from anyone try this...turn the eccentric so its sitting at 90* to ground on its outward stroke...next slide cutting bar to its furthest stroke and measure...next turn everything 180* and measure again...split the difference and you got your length...after you get arm made turn eccentric so spindle is dead center on top and check your cutter...blade should be dead center inside guards.
good luck
Old Iron In WI.
11-04-2006 18:07:26
I have a new pitman for a 27V (P/N M32119). Please contact me by e-mail if interested.
Gene Kidd (Old Iron)
