question flywheel new holland baler
john new
11-04-2006 10:18:03
New holland baler with same play in the flywheel (move back en forth).
What to do Replace the flywheel busch or tight the Shear bolt more.
Whats the best!!!!!
paul
11-04-2006 18:32:54
 Re: question flywheel new holland baler in reply to john new , 11-04-2006 10:18:03
Is the flywheel moving on the shaft, or is the shaft the flywheel bolts to moving back into the gearcase? You got several surfaces in there, be sure which one we are talking about.
--->Paul
sam webb
11-21-2006 06:22:54
 Re: question flywheel new holland baler in reply to paul, 11-04-2006 18:32:54
yes the flywheel moves or turns the shaft that goes into the gear box
I have a 66 also that I just got about a month and a half ago and they are one good baler
