Stump pulling
Tyler(WA)
02-22-2000 14:07:11
I thought I would make a new post and include a few drawings.
Here are two harness techniques that use a single pulley to greatly improve the pulling power of your tractor.
Here's the first:
third party image
With the block chained at the high end of the stump you want to pull and a cable anchored to a bigger stump (or tree) run the cable through the pulley and then to your tractor's draw bar. This will give you about twice the pulling power compared to a straight pull.
Note the use of a steel wheel rim that's chained to the trunk base. This will leverage the stump up and out of the hole as the stump is pulled over.
In this second application, a cable is tied tight from the stump to the anchor point. The pulley is free to slide on this line and a third line can pull the pulley block to the side. This method will offer even greater pull at the start.
third party image
Mowman
02-24-2000 07:38:45
 Re: Stump pulling in reply to Tyler(WA), 02-22-2000 14:07:11
Tyler, your information on stump pulling is interesting. I have never owned any cable and pulley set-ups. What is the strength/construction of what you use? Is there any danger that a broken cable could snap back and cause injury?
Tyler(WA)
02-24-2000 09:21:15
 Re: Re: Stump pulling in reply to Mowman, 02-24-2000 07:38:45
What we call "steel cable" is officially called wire rope. True "cable" is much too stiff and not suited to use with a pulley.
None the less... the "cable" I use is 3/8" and will stop my tractor's forward motion before it would break. I know some who use 1/2" because they use runs of several hundred feet with pulley's to double their pull.
Wire rope does not recoil when it breaks. It's a lot like chain but a LOT cheaper. However it doesn't grab onto itself like chain will so I use a length of 3/8" or 5/16" chain on the end of my cable for grabbing onto things. I don't remember the load strength of 3/8" wire rope but when I checked it out, it was more than strong enough for my needs. I've pulled the thimble off the end of my cables before (because I was too cheap to use two cable clamps) but I've never borken a 3/8" cable. I have broken several 1/4" cables.
