jd horse power lubrication
wally b
11-03-2006 07:56:47
I have a jd sweep horse power, where the horses walk in a circle and drive a bull gear that runs a set of rack and pinion gears to a final shaft output. The center gears rotate on vertical shafts and there are oil holes thru the cast housing that holds the upper end of the shafts. The shafts are fixed and the gears rotate on the shafts, but there are no bearings, babbets, or bronze oil metal. There is no room for these either. So I'm wondering what kind of oil to use?
wally b
burnetma
11-04-2006 18:46:51
 Re: jd horse power lubrication in reply to wally b, 11-03-2006 07:56:47
Any idea on the total clearance between the parts? The larger the clearance the higher the desired viscosity. I am thinking grease or gear oil. Not sure if extreme pressure additives would be necessary.
Phil Munson NY
11-03-2006 09:50:13
with no bearings or bushings; use really good oil, stuff that will stay in ther and work for you. best, Yeoman
