8100 IH Drill
Yongfarmhand
10-31-2006 17:08:44
I was wondering how much HP is needed to pull a 8100 Case drill, or a 7000 JD corn planter, and what does everyone think of these two implements.
Mark 2 in Ohio
11-01-2006 11:46:30
 Re: 8100 IH Drill in reply to Yongfarmhand, 10-31-2006 17:08:44
We pulled a IH 5100 21 hole grain drill with a JD 50 in 4th gear (about 30 HP). Didnt even work it at all. COnventional tillage.
Not sure how large an 8100 is...
ChrisLSD
11-01-2006 07:46:19
Uncle pulled a 4 row 7000 no fertilizer no water with a JD 60 for many years
JMS/MN
10-31-2006 20:52:22
JD 7000 is what revolutionized planter design, and all others copied it. First time that seed placement depth was set and controlled near the opener, instead of the planter wheel. Seed singulation was a new concept as well. HP requirement depends on how many rows you are pulling, carrying fertilizer, etc. or just planting. Fert boxes hold about 550 lbs per two rows. 3020 on a 438 with dry fert worked well, 4020 was a good minimum match for the 830 with dry fert- held 2200 lbs. Even with duals, was a good idea to plan for the low spots. Dualed 4430 and 4240 was not a problem.
