used implement salvage yards
Jim R
10-30-2006 19:59:00
I have a John Deere 943 wagon gear that I am restoring and I need two tie rods for it. The part # is: S 3406 DW, Deere says that part is no longer available. Does anyone know of an equipment salvage yard that has implements? Thanks for any replies!
cdv
10-31-2006 16:46:12
 Re: used implement salvage yards in reply to Jim R, 10-30-2006 19:59:00
junie Fry in Pa
wilman
10-31-2006 12:09:58
How bad are your tie rods? I restored my grandfather's 943 this last summer/winter and it had one tie rod that had been broken off and welded into a pipe somewhere along the way. Bought a hardened bolt and had a friend weld it on to the end and than had a machine shop put some more threads on it. Works real good and after it was painted, you can't tell the difference. Big thing is on those tie rods is to get the proper angle to the end where it attaches to the spindle. If that isn't correct, the steering won't work. I had to do a little bending in the vise to get mine just right to steer correctly.
Here are a couple of pictures:
The broke tie rod before I pulled the gear out last fall:
third party image
The completed project with hand crank hoist and wooden flare box:
third party image
Wil
Gerald J.
10-31-2006 08:16:24
Kalsem Salvage at Waterloo, Ia
Colfax Tractor at Colfax Ia more implements at their neighbor Sean Coogley, but they know how to find him.
Gerald J.
IaGary
10-31-2006 04:26:45
Don't know of any salvage yards.
Some parts like tie rods can be made at your local Machine Shop to match the orginal and might be cheaper.
Give them a try.
Also there are weld on ends available if it is just the ends that are bad.
You cut off the old end and weld on a new ball socket.
Gary
