How do you tell a Little Genius from a Little Wond
John P.
10-26-2006 09:05:13
How do you tell a 2 bottom Little Genius from a Little Wonder plow? I"m guessing it is one of these since it is marked PO in several places.
Jeff Wenner
10-26-2006 09:46:40
 Re: How do you tell a Little Genius from a Little in reply to John P., 10-26-2006 09:05:13
The Little Wonder was the bare bones economy plow. On the Wonder, the tail wheel is just bolted to the plow frog, or it may have no tail wheel at all. The Little Genius had more bells and whistles. The tail wheel on the Genius is connected by a linkage to the lift axle, and the hole assembly actualy pivits and lifts the back the plow. There are other differences but this should be the easiest to pick out. If you search the Implement Photo Gallery to the left, there are lots of pictures of both.
John P.
10-26-2006 11:25:30
 Re: How do you tell a Little Genius from a Little in reply to Jeff Wenner, 10-26-2006 09:46:40
The tail wheel does not have any linkage (just bolted on), so that must mean it is a Little Wonder then.
Thanks!
