JD plow
gunner_1911
10-25-2006 05:20:51
I'm trying to identify the model number of a Deere plow. It's hydraulic lift, 3-16's, with trip bottoms. It's new enough to have the square beam on top as part of the frame. Oh, and it is a pull type. Any ideas? Is there a website that can help? Is there any stampings anywhere on the plow that would help? Thanks
Jim
msb
10-25-2006 07:11:03
 Re: JD plow in reply to gunner_1911, 10-25-2006 05:20:51
If its a large beam about 4"x6" then it is a 620 or a 630,I can't remember which.If it is a solid beam about 2"x2" then it is either a 555 or a 666.Spoked wheels or solid rims? Large or small tailwheel?
gunner_1911
10-25-2006 07:29:44
 Re: JD plow in reply to msb, 10-25-2006 07:11:03
It is the large beam. Solid rims, and I"m not sure about the tail wheel. How large is the large, and how small is the small?
thanks
Jim
msb
10-26-2006 18:28:02
 Re: JD plow in reply to gunner_1911, 10-25-2006 07:29:44
Sounds like a mate to my 620-630,whatever.Small is 4.00 X 12, I think.Large is the same as the other two wheels. Mine is a small tail wheel.
gunner_1911
10-27-2006 04:00:40
 Re: JD plow in reply to msb, 10-26-2006 18:28:02
After I made the statement about small/large, I remembered a couple old plows we had when I was a kid. This current plow is deffinitly the small wheel. You are right, the large is the same size as the others. If you happen to have, or know of someone who has the hitch hook and then latch, for one of these, I need both.
thanks!!
Jim
