Pure notill does not work in my part of Minnesota either. I'm in the heavy, wet, clay, snow-band part of southern MN. I hope strip till does some day. I see 3 of the 4 neighbors that were min-tilling cornstalks brought the plows back out this fall. And we've had dry winters of late! :) Anyhow, if you are in the sandier parts of the state where the snow doesn't pile up so bad all winter; Your best bet will be a used no-till planter. The bolt-on attachments, bought new, are _not_ cheap. Making your own out of scrounged parts - will have limited success. Starting with a lightweight planter, if you do get the strip/ clearing units on, and add weight, and add heavier down springs..... . Bushings wear out fast, parts start to break. You can do it, and if you are good at scrounging & such one can get stuff together for lower bucks. But if you think long term, it doesn't always work out so well for the pocketbook. Frame members, bushings, etc. will be stronger on a no-till planter, even if they look pretty much the same as a regular.... --->Paul
