Parts for Big Bee Finish Mower
Pooh Bear
10-19-2006 23:33:18
I have an old, abused Big Bee finish mower.
I picked it up a couple of years ago for $250
and it has mowed great. But I have to replace
the belt every year. Twice this year. $50 each.
It needs an idler pulley and the main pulley.
The idler pully has loose bearings that allow it
to lean to one side and the main pulley has edges
that are worn to a razor sharp edge.
Otherwise it mows great.
But where can I get parts for a Big Bee finish mower.
I had to get blade bolts for it a while back
and blade bolts for a King Kutter were an exact fit.
The main pulley looks the same as a KK also but I need to check that out more.
And I'm sure the idler pulley is just a generic item.
Thanks.
Pooh Bear
Tracy Brown
10-20-2006 09:23:29
 Re: Parts for Big Bee Finish Mower in reply to Pooh Bear, 10-19-2006 23:33:18
If it is the BigBee that I am familiar with, they are made a few miles down the road from where I live (N.E MS). I went to the factory and bought a set of blades for mine without any problem. I have 2 phone # for their plant in Tremont, MS 662-652-3372 & 662-652-3374. Maybe this will help if you can't do any good locally.
Pooh Bear
10-20-2006 12:11:20
 Re: Parts for Big Bee Finish Mower in reply to Tracy Brown, 10-20-2006 09:23:29
Thanks for the replies.
The phone numbers will help a lot.
And I did find a free download manual on the
agequipmentusa website. So I have the part numbers.
I checked SweetTractors. He can probably get parts for it.
I was told the mower originally came from a local co-op.
I went to our co-op and they didn't know anything about it.
Then I remembered a lot of people shop at the co-op
in the next county up so I need to check there too.
I like this mower. It has been thru a lot of abuse
in its lifetime, but it still mows great.
And anything that goes wrong on it can be easily fixed.
Provided I can find a parts source for it.
Thanks.
Pooh Bear
Jim West TN
10-20-2006 06:00:45
Try one of your Co-ops, you have one or two a county in your area. Or agequipmentusa is the division of co-op that that handles parts. They do carry Big Bee. Jim
Rick Kr
10-20-2006 04:44:35
Dont know if they have parts but a place by the name of Sweet tractors in KY lists a ton of Big Bee cutters on their website site.
Never bought anything from them, but maybe worth a try to call them.
Rick
504-1
10-20-2006 17:52:52
 Re: Parts for Big Bee Finish Mower in reply to Rick Kr, 10-20-2006 04:44:35
Try a local bearing supply co. Here it would be Motion Industries. They should have the idler and a pulley too.
