Older Jd 8300 series grain drill settings for seed
Starvation ridg
10-19-2006 06:50:05
I need some info on settings for winter whest on a older 8300 drill with 7 in. spacing. I would like to plant 80 to 90 pounds to the acre. I have no chart or manual at this time so if anyone can help me get in the ballpark thanks very much! Rob
Starvation ridge farm
10-19-2006 20:47:48
 Re: Older Jd 8300 series grain drill settings for in reply to Starvation ridge farm, 10-19-2006 06:50:05
Thanks very much for all your help. Ifin it ever stops raining I will give her a try!! Thanks,Rob
Devin Sparks
10-19-2006 08:57:41
I have a 8250 that I plant wheat with. I planted 100 lbs / acre. I set the gate at 20-22. Hope this helps.
Devin
JMS/MN
10-19-2006 08:57:22
Manual for a FLUTED drill shows 78 lbs at notch 20, 94 lbs at notch 24. Feed cups should be set at uppermost notch of the three- small seed, so the cup is closed down the most. DOUBLE RUN drill is set different.
