2 row corn picker
budaa
10-18-2006 11:13:57
I am going tomorow to look at a new idea two row corn picker. the guys says he bought it new 25 years ago. last used it four years ago. it is a 12 roller not and 8 whatever that means. I need to know all of the things to check out on this picker. i have not a clue what to look for. He is asking $1000.00 for it and wont come down. also can i pull this with my pick up about 70 mi to get to my farm. want to use it to pick corn to bag and sell to the deer hunters and some neighbors for goats and cattle. thanks will be pulling this picker with a farmall 400 will this do the job. fairly flat land some rolling hills
CraiginMO
10-19-2006 06:44:46
 Re: 2 row corn picker in reply to budaa, 10-18-2006 11:13:57
Come to MO. They practically give them away here. Nice units bring maybe $300 if they are mint. $1000 would be a gold plated model here.
IaGary
10-19-2006 04:36:19
Budaa as far as pulling the picker,take a hand cable winch with you.
When I pulled mine home it got to swaying back and forth.
If I would have had a cable winch with me to hook to the outside snoot to pull toward the hitch to take the slack out on the swing pins I think it would have trailed a lot better.
Picker sounds okay to me.
Gary
James2
10-18-2006 20:09:11
The 12 row husking is a "must have" in today's higher yielding corn. We had a 325 (2 row 30 inch) with a 8 row bed and it was always overflowing in 140 bu/acre corn. If it is a 325 with a 12 row bed, $1000 is not a bad price. I would guess it would bring $1500 in this area. A model 324 (two row wide)is worth somewhat less. I have a model 330 (three row narrow) with husking bed and sheller. Paid $3000 about 10 years ago. Don't do ear corn anymore, but will use the sheller and park the combine if harvest progress allows some fun time.
doc diesel
10-18-2006 19:51:21
they are nice pickers, we have 7 of them. but when you start changing bearings in the husking bed you will add new words to your vocabulary! trust me.
730virgil
10-19-2006 08:42:19
 Re: 2 row corn picker in reply to doc diesel, 10-18-2006 19:51:21
that and tie a string to box end of wrench i proimse you will drop wrench at least once into places unknown and it's a B looking for it in my case them as we i dropped more than one
paul
10-18-2006 19:47:04
A 300 pulls the picker just fine, if you have a 100 bu barge box. With a 200 bu gravity box, gets a little low on hp just for the weight of the wagon. The 400 should do fine.
Good picker, basicly look over all the sprockets & bushings & see if the rubber fingers are all there - they are _way_ spendy to replace - and look for rust-through at the bottom of the 2 elevators.
--->Paul
730virgil
10-18-2006 18:52:16
dealer i worked for in mid 70s sold lots of them . good picker i would think 400 should handle it might be a little slow going . towing 70 miles behind pickup won't be fun as i rememder didn't trail the best .
dboll
10-18-2006 13:39:46
If you want clean corn in the wagon, want to go a decent speed and don't want it all shelled on the ground the one to buy is a new idea!
NEsota
10-18-2006 13:31:37
A friend of mine has an IH two-row mounted picker (wide rows), that has always been sheaded and is in great mechanical condition. It is in S.E. Nebraska and could probably be had for $500. The mountings are for a 400. My email is open if his name and phone number are wanted.
kyhayman
10-18-2006 12:49:21
Price of pickers is definitely location driven. Any decent 2 row on a dealers lot here is oer 2500.
bradk
10-18-2006 11:27:36
The 12 roller is refering to the husking bed.A 12 cleans the corn husks off better.
A thousand is high for a picker.Around here $800 is the most I've seen them go for.
The 400 will pull it fine.See if you can have the guy run it for you.Where are you located?We have a like new NI 324 for sale.~brad
budaa
10-18-2006 12:35:06
 Re: 2 row corn picker in reply to bradk, 10-18-2006 11:27:36
located in souteast michigan, farm is in hillsdale michigan. what are you asking for your picker. is it a two row and 30in rows. that is what my planter is set up for. a two row 250a IH
bradk
10-21-2006 20:52:30
 Re: 2 row corn picker in reply to budaa, 10-18-2006 12:35:06
Nope sorry.Wide row.$850.00
We use an Oliver 83NR(30in.)which is why the NI is for sale.~brad
INCase
10-19-2006 11:38:04
Check this web site. there is a 325 listed. ALso a NewIdea Uni w/2row picker for $900. It would be 2-3hours from you. >Link
For>Link hobby farming why not look at a 1 row picker? would be a bit cheaper(maybe) and easier to pull. Good luck.
