The area is 120X120, and that would be alot of roundup. aside from the cost, my father would have a fit if he found out I was using that much roundup around the well. Say what you all will, but I have done research about it and dont like what I read, so I'm not even going to consider it, altho that vinegar recipe I'm curious about for maintenance. These are no TOYS. My Savage monster truck is 1/6th scale (after my ext chassis and offset rims), does around 55mph, 3 speed auto tranny, and can easily do double back flips, land in horrendous ways and keep coming back for more. My engine is a Picco .28, RATED (actually higher) at 3.8 HP. My truck weighs around 14lbs. My buggy is a Hyper 7 PBS PCR with a Picco .27 The buggy does 45 easy and it is a single speed, if I went with the 2 speed (alot harder on the difs because it eliminates the center dif), and regear it, I could do 70 EASY. My onroad car does appx 60 stock. You think these are toys? I wish I had the link for the video. One of my good friends designed and made OTB gears for the older (now defunct basically) Traxxas T-maxx. The only aluminum 2 speed gearset ever made for the tmaxx. He also designed the infinity gearset which makes it possible to gear the tranny VERY low. So low infact, he pulled an S-10 with it. Sand in the tires, and a Rowdy C-5 engine did it. I'm sure most of you still consider these toys, but oh well. I still enjpy the board and most of you guys =) I will probably try a different drag, not quite sure what I'll do yet really. What does a scraper do? Could propbably use one for maintenance.
