JD plow identification
Josh Wilhelm
10-08-2006 11:49:38
I have just purchased three JD plows all are on steel wheels. I believe that they are all 16in bottoms. I dont know how to identify them. I have found numbers on the plows can someone tell me if the numbers mean anything. the first one is 15452 on cross beam and 612&613 on the plow beams. The next is 18434 on the cross beam and 623&683 on the plow beams it also has a much larger lift wheel. The last one has 15833 on the cross beam and no numbers anywhere else HELP?
Bob Collins
10-11-2006 06:56:56
 Re: JD plow identification in reply to Josh Wilhelm, 10-08-2006 11:49:38
I just got home and am coming in late on these answers, your first plow is a #52, and the second is a #4 series most likely a 4B built before 1942 since it has the 32" land wheel. The third opne is a #45 plow, that is a much less common plow built from 1919 thru Feb. 1937. Sounds like a good collection!
Earl-IL
10-08-2006 14:57:03
My 4B plow book list 623 & 583. might the 6 be a 5 on the 683 beam. The 623 the long beam the 583 the short Earl
Josh Wilhelm
10-08-2006 15:37:37
 Re: JD plow identification in reply to Earl-IL, 10-08-2006 14:57:03
Hey Earl you are correct on the numbers it is 623&583 so what does that make the plow. I did some more looking and found some numbers on the other plow. The numbers are 515&516 so what is this plow.
Earl-Il
10-08-2006 18:47:59
 Re: JD plow identification in reply to Josh Wilhelm, 10-08-2006 15:37:37
I would say a 4B about 1935-1949 Earl
Stan - Florida
10-08-2006 17:03:47
The 515 & 516 beams would make that one a No. 40 plow, which was originally built for use with a Fordson tractor.
Still can't help on the 623 and 583, however.
Stan
Stan - Florida
10-08-2006 12:21:30
612 & 613 make that one a No. 52 plow. I don't find any info on the 623 & 683 numbers.
Stan
Josh wilhelm
10-08-2006 13:19:18
 Re: JD plow identification in reply to Stan - Florida, 10-08-2006 12:21:30
Stan thank you for your info I dont know much about plows I purchased some tractors and I ended up with the plows. A little more info the plow with the 623&683 came with slat bottoms that arn"t mounted to the plow ther isn"t any bottoms on it.They have JD numbers on them I believe thats what they are called. The plow looks similar to the #52 except the larger lift wheel. The other plow is quite different it looks lighter dutty maybe older no beam numbers.
