3 point and loader?
Mary in Pierz
10-06-2006 19:35:54
We just purchased a JD60 with a loader, and want to add our 3pt. Can I run both? The rockshaft will not turn.
Carl NY
10-08-2006 07:39:43
 Re: 3 point and loader? in reply to Mary in Pierz, 10-06-2006 19:35:54
Mary- It can be done with a special plug available from Deere. Part # F-2250R. It is a variable flow control valve. Deere may have in inventory. Coupling- special for parallel operation of remote cyl. & rockshaft.
MikeinKy
10-07-2006 07:11:13
You can't use both at once. You need to remove the loader connections and install dummy plugs before the rockshaft will move. You can use either the rockshaft or a cylinder, but not both at once.
jhill52
10-06-2006 20:17:18
Go over to the John Deer board and look around. It has been discussed several times. It takes a different type of hydraulic connector.
MaryK
10-06-2006 20:27:50
 Re: 3 point and loader? in reply to jhill52, 10-06-2006 20:17:18
Thanks-I will do that
