JD hydraulic cylinder blowing seals
Illinois Farmal
10-04-2006 18:27:24
I have an older John Deere hydraulic cylinder that keeps blowing the seal out. There's one like it in the implement For Sale board. As soon as I put pressure on the cylinder it blows the seal out. This has happened twice now. The first time I had the 2 pins in the outside shafts and thought that was the cause. I removed them, put a new seal in and it blew out right away. What am I missing here???? Thanks for any help.
burnetma
10-05-2006 14:05:38
 Re: JD hydraulic cylinder blowing seals in reply to Illinois Farmall, 10-04-2006 18:27:24
Better than Polar Bears...
Sorry I could not help myself! Smile it is almost Friday.
Eli
10-04-2006 18:34:33
The older JD cylinders are only ment for about 850psi. My guess is the tractor your using has several more pounds, most do. You can probably sell it and get enough to get a brand new one. Good luck, Eli.
