Another question from a new and confused guy.
KBJ
10-04-2006 08:23:35
I am thinking of gettin a Ford 2000. What size plow, disc, and brush hog do I need. Also, how do you know what fits on what tractor?
Thanks,
KBJ
JOHN HARMON
10-04-2006 17:01:08
 Re: Another question from a new and confused guy. in reply to KBJ, 10-04-2006 08:23:35
I owned and used a 2000 series Ford with a Superior Loader and Ford Scraper Blade. A 2/14" Mtd Ford Plow, a 6-7' Three point Disc and a 5' three point Rotary Cutter all will work nicely with this little Tractor. This Little Tractor is a dream to operate with any of the mentioned equipment. It also is great to rake Hay with or to pull Hay Racks etc. with.
Jim.UT
10-04-2006 08:56:24
The 2000 should have what's known in the industry as a Category 1 (Cat 1) three point hitch. Bigger tractors have Cat 2 and Cat 3 hitches. Little lawn tractors that have a three point hitch will have a Cat 0. The category size refers to the diameter of the pins, etc. So as long as you buy cat 1 equipment, it will fit your 2000 hitch.
Matt Page
10-04-2006 08:44:31
I have used a ford 2000 diesel for the last twenty years. If you're new to tractors you can't know without asking other than just common sense. You'll need your implements to attatch with a three point hook-up. A 2000 will handle a two bottom twelve or fourteen inch wide plow in most soils (hardly in clay, due to wieght of tractor not getting traction). It will match up nicely with a five foot brush hog and a six foot tandem disk. Let me know if you have other questions. They're good tough tractors. -Matt.
