Mower deck fit
vrickster
10-03-2006 16:07:07
Will the Deck described below fit a Ford 8/9N? How about a JD M?
Ford 9168 Mower Deck No. 22AB5304, Serial No. YF10952, 60" wide used with a Ford 1510 Tractor
Brendon
10-04-2006 18:27:30
 Re: Mower deck fit in reply to vrickster, 10-03-2006 16:07:07
I'm not positive on this, but based on the description of the mower I would guess that it is a belly-mounted type, especially since the tractor it was used with is mentioned. If it were a three-point type, it would most likely have said so. If it is a belly-mount deck, it was probably designed to fit only one specific series of tractors like the Ford 1510 mentioned. This would mean the linkages and drives are pretty specific. To adapt it to a different tractor would be an engineering and fabrication challenge, especially when it comes to the drives.
If it is a three-point mounted mower, it would probably work on the 8N/9N. The JD M was not available with a three-point hitch but had a proprietary implement lift. They can be (and mine has been) converted to three point, though.
