Brush Hog trailing wheel
Bradley
10-02-2006 18:57:26
The trailing wheel on my old brush hog was catty-whompus when I finished mowing last week. The bearings are totally shot. I have no idea what kind of mower it is.
Has anyone been in this position before? Do I take the wheel assembly in to a tractor dealer and see if they can match up the parts? I don't want to spend a fortune on it....it's not worth it.
Any suggestions?
Thanks
Brad
RayP(MI)
10-04-2006 17:37:43
 Re: Brush Hog trailing wheel in reply to Bradley, 10-02-2006 18:57:26
My NAPA dealer was able to fix me up with bearings for my off brand brush hog wheel.
Bradley
10-04-2006 08:27:34
Update....I took the wheel to the local JD dealer, and he looked up in his computer trying to find a similar wheel configuration, and didn't find any. He sent me to a FNH dealer, and same thing there.....no luck, but the FNH dealer sent me to a bearing supply house. They were able to remove the race, get the number off of it, and $42.00 later, supplied me with new races and bearings. They fit like a charm!!
Thanks for your input.
Brad
Bradley
10-03-2006 12:42:06
Thanks for the input guys. I took the wheel off last night, and will stop by the local JD dealer (only one close by) and see if they can match up the bearings, etc.
I'll see if there's a TISCO dealer nearby also.
I'll let you know how I come out.
Thanks!!
Brad
Glen in TX
10-03-2006 07:35:34
Find a TISCO dealer near you. woodsonline.com (TISCO dealer locator)
bjr
10-03-2006 06:25:44
 Try Agri-Supply in reply to Bradley, 10-02-2006 18:57:26
I seen wheels and shafts and bearing in their catalog and the prices didn'tseem to bad. I want to change mine over to cone roller bearings instead of the bushing and use one of them composite rubber tires they have. bjr
SW Georgia
10-03-2006 04:05:52
heck my field so so rough up and down, I took my wheel off and put it in the shed.Adjusted the deck where it was about an inch above ground when in down position ..... wished I had done that a long time ago,no more scalping
BCnT
10-02-2006 20:37:18
i had a old sabre 5' shredder that the wheel fell apart...got a swiveling caster wheel from northern hydraulics for less than 20 bux and welded it onto rear of shredder...worked for a long time till shredder finally broke in half.
i think it was a 8'' wheel with pnuematic tire and a greasable bearing.
Kelly Campbell
10-02-2006 19:05:20
You can take the wheel asmbley into a parts dealer and they should be able to match it up, pretty well regardless of what kind of mower it is, for the most part the wheels are pretty standard
