MF 10 baler
RoninKS
10-01-2006 21:45:11
I've been looking for a dependable small square baler, and I ran across this local classified today:.... Model 10 Massey small square baler good condition, $200.00.
How old is this baler, and were they pretty good balers? It would be used on 40 acres of alfalfa, and 35 acres of broome grass.
Are parts for the Model 10 still available?
Thanks for any info concerning this baler,
RoninKS
burnetma
10-03-2006 04:19:47
 Re: MF 10 baler in reply to RoninKS, 10-01-2006 21:45:11
I am not sure about the vintage of the MF10, but I would expect that it was made in the 1950's. Parts are still available. It will work well if properly adjusted. It requires only 16 pto HP to run the baler mechanism and I would say an older 35 HP machine would handle it nicely on the flat.
The bad news is that it is a very low capacity baler. For comparison, I have a MF10 and a JD327 with a pan thrower. Baling onto the ground, the maximum number of bales that I could put through it is about 500/day (only did it once and it wasn't easy). I can easily double that with the JD and have it in wagons. With the kind of acrage you are talking about, I would look for a bigger baler than the MF10 and possibly bigger than the JD327. Unless of course you have all the time, good weather and patience in the world. I would expect your yield to be somewhere in the neighborhood of 15,000 bales per year. You may wish to look into having a neighboring farm or custom hay baler look into making this hay off for you. That is a lot of work unless you have a good labor pool to draw from.
If it were my operation and I was set on doing the hay myself, I would be looking for a JD 336, 346, 337, 347, 328, 338 or 348 baler with a kicker -OR- with a quarter turn shoot and a NH bale wagon. You will need at least a 55 PTO HP tractor with more being better.
Hopefully others will chime in and give their opinions and experience.
RoninKS
10-03-2006 10:26:14
 Re: MF 10 baler in reply to burnetma, 10-03-2006 04:19:47
Thanks burnetma for the info.
I'm not sure what I've gotten myself into, because I bought the Model 10 yesterday evening.
My time is pretty flexible, but I don't have a "labor pool" to pull from, so it sounds as though I might be in for a lot of work,... especialy for my age which is 63. LOL
Any other comments are surely welcome.
RoninKS
Jossette
10-03-2006 17:41:11
 Re: MF 10 baler in reply to RoninKS, 10-03-2006 10:26:14
I have a # 10 and if you have any questions, look me up..
burnetma
10-03-2006 13:25:32
Do not despair. All is not lost. First off you are only out $200 which is less than what a working MF10 is worth. Secondly, having a low capacity baler is OK as it will force you to work smart. Only cut as much hay as you can bale in a day (2-5 acres). Get at least two bale wagons. Find somebody to work in the wagon and stack the bales on the wagon as you go. At the end of the day you can cover the wagons and unload during cooler temperatures (morning).
What do you intend to do with the hay??
RoninKS
10-03-2006 20:57:51
 Re: MF 10 baler in reply to burnetma, 10-03-2006 13:25:32
Thanks fellas for the replies.
My small square bales of alfalfa will get fed to my horses and burros, and will only amount to 1 cutting per year. The rest of the cuttings off my acreage will get baled into big round bales.
RoninKS
jerrycpp
10-01-2006 22:04:25
I have had a 3, 10, and a 12. Parts are still available from Massey Ferguson. As near as I can tell, they were built from the mid-50s through the 60s. Owner and parts manuals are about $14 each from the dealer.
