rubber tires for John Deere hoe drill
Gtrible
10-01-2006 17:53:26
Can anyone tell me where I can find new rubber for press wheel a John Deere Hoe Drill
Glen in TX
10-01-2006 18:58:18
 Re: rubber tires for John Deere hoe drill in reply to Gtrible, 10-01-2006 17:53:26
You didn't say which size, type or drill? The hard rubber ones for spoke type wheels were available from JD if you can afford them. Something like the LZ drill with 4.00-18 rib implement tire you are only going to find in Firestone probably. We still run some LZ drills with those tires on them. Parked the others with hard rubber tires for parts because those cost to much to fix. If you meant the smaller press wheels on other drills try JD or shoupparts.com or sloanex.com or A&I or TISCO dealers, aiproducts.com woodsonline.com
