535 Baler Tensioner Problems
J Wynne
10-01-2006 07:59:29
I am having a problem with my baler making to tight of bales. I have adjusted the tensioner but it does not seem to make any difference. When the bale gets around 5x5 it is so tight that it just shaves off the hay that it is taking in and stops up. Any ideas on how to correct this. I just purchased this baler. It will also not self tie. You can manual tie but it will not self tie. I am guessing it is to do with the tensioner. IF you cycle it with the gate locked and baler empty it will self tie. I hope this is clear
jwynne
10-02-2006 06:51:51
 Re: 535 Baler Tensioner Problems in reply to J Wynne, 10-01-2006 07:59:29
JD 535 Baler. I am adjusting the tension at the valve but it seems not to make any difference. Has anyone had the tensioner valve go bad? the moisture content is around 20% when I baled last time in sudan. I am also having the baler not self tie.I have checked and all seems ok. What happens is it makes such a tight bale that it starts to shave off the hay on the bale and through it back in front of the baler because the tension is too tight. IF you put the remote in float it works a little better but not correctly.
Tx Jim
10-03-2006 03:15:17
 Re: 535 Baler Tensioner Problems in reply to jwynne, 10-02-2006 06:51:51
Tension valves and cylinders can go bad but usually bales won't be tight enough. Normally if you back tension valve out far enough the tension arm inside baler won't work properly. What pressure does gauge show(12 o'clock or 2 o'clock) Are your belts the correct length? If tying mechanism doesn't latch when gate closes then baler won't auto-tie. Check to see that belt that pulls pump has no tension on it after gate is closed. Tx Jim
Tx Jim
10-02-2006 03:05:42
Are you refering to a JD 535? What is moisture content of hay as what you describe hay is too dry? How are you decreasing tension? Tx Jim
