Driveline parts - I need suggestions please
fixitforfree
09-29-2006 21:09:48
I need some 1 5/16" solid square shaft and the square tube it will slide into to make a driveline for an old Servis E60 pull type mower. Does anyone reading this have some I can buy? I need to span 60" overall so I need about 3.5 feet of the male shaft and female tubing. Help if you know where I can buy some. I am in Texas.
J Schwiebert
09-30-2006 11:34:05
 Re: Driveline parts - I need suggestions please in reply to fixitforfree, 09-29-2006 21:09:48
HAve you looked at any driveline catalogs? How much slip do you need? I just had my Neapco PTO catalog out, guess I can look again. If too oddball I would convert to something morse standard. Questions?
Glen in TX
09-30-2006 08:21:22
Check with some of your local machine and welding shops around there that do lots of ag repairs. We have several around here that keep drive line components and the tubing and they can just build up new or fix about any kind of drive shaft you bring in to them. I've bought it myself before too and got a jig I lay it on to get them aligned and then roll it on jig while running the wire welder around it or can even weld it with a stick. Otherwise look on these dealer locators for TISCO, www.woodsonline.com or A&I aiproducts.com
IaGary
09-30-2006 05:00:10
Try checking this site www.sloanex.com
I looked in there parts catalog but didn't see any 1 5/16 but a lot of 1 1/4.
They also have complete shafts.
Also make sure its not rectangle instead of square.
Gary
fixitforfree
09-30-2006 06:36:55
 Re: Driveline parts - I need suggestions please in reply to IaGary, 09-30-2006 05:00:10
Thanks Gary. They don"t have exactly the shaft and tubing I need but I bookmarked the site. They have much that I can use in the future. I thought someone on this site might have some of this square shaft and tubing laying around they might sell me.
Gerald J.
09-30-2006 10:40:42
 Re: Driveline parts - I need suggestions please in reply to fixitforfree, 09-30-2006 06:36:55
Try Baum Hydraulics at Omaha. www.baumhydraulics.com
Gerald J.
