Little genius plow parts
Scott KY
09-28-2006 14:57:11
I need the handles and the rods that are used to adjust the depth and leveling levers. If anybody has these to sell please contact me.
Earl-IL
09-28-2006 20:16:29
 Re: Little genius plow parts in reply to Scott KY, 09-28-2006 14:57:11
Whats wrong with yours ? Are they missing? Earl
Scott KY
09-29-2006 03:48:09
 Re: Little genius plow parts in reply to Earl-IL, 09-28-2006 20:16:29
Yes, they are missing.
RustyFarmall
09-29-2006 05:43:24
 Re: Little genius plow parts in reply to Scott KY, 09-29-2006 03:48:09
Is the entire assembly missing or just a part of it?
Scott KY
09-29-2006 11:36:21
 Re: Little genius plow parts in reply to RustyFarmall, 09-29-2006 05:43:24
I have the levers, the L shaped pins, and the springs. I need the small handles that you pull that mounts on the levers that stick up toward the tractor. I also need the 1/8 inch or so rods that connect to the L shaped pins. Thats the best way I know to describe them.
RustyFarmall
09-29-2006 12:14:21
 Re: Little genius plow parts in reply to Scott KY, 09-29-2006 11:36:21
Some havy and stiff #9 wire will substitute for the rods, and with a little imagination, you can make new handles. That's what I had to do on mine. I know it isn't original, but it looks good and it works.
