New Holland 469 hay cond.
keith theobald
09-27-2006 14:53:02
Going to a sale Sat. with a 469NH hay conditioner .Are they any good ? when were they made ?I only have 7 ac. of hay
jiskies2
09-27-2006 19:25:27
 Re: New Holland 469 hay cond. in reply to keith theobald, 09-27-2006 14:53:02
have used one for years... maybe not as good as a discbine but not as costly. definitely check the rubber on the rollers and knife bar area. ours is starting to rust out a little..
jeff
GGG
09-27-2006 16:27:22
If you only have 7 ac of hay don't spend over $250 for it. In the spring it might bring $500.
KEH
09-27-2006 15:58:13
I had one. Good machine, it will float over rough ground.
I think they were made in the late 1960's. Look for rubber missing on rollers, they are expensive to replace. Look at drive belt, if it needs replacing it is a pain to replace, involving removing gear box from frame.
Look along cutter bar to see if it has been bent.
New Holland has well engineered products, but some of their equipment including the 469 was made from thin material. Therefore, if the machine shows signs of sitting outside it may have serious rust problems. Don't know about price it may bring.
KEH
