Looking for plow leighs
russ 302
09-26-2006 20:00:47
Does anyone know where i could find new plow leighs for a two bottom plow case and a three bottom plow minn.moline?
newtothisgame
09-28-2006 10:10:15
 Re: Looking for plow leighs in reply to russ 302, 09-26-2006 20:00:47
where do u live if in or near MN email me if you want some off an old plow for the mm and mabey the case
55 50
09-27-2006 11:00:30
My dictionary doesn"t list "leigh", I suppose you mean "lays" which many plow people use to describe the cutting portion of the moldboard. "Lay" doesn"t come up in my dictionary as anything to do with plowing; makes me wonder where these words came from originally.
Gerald J.
09-27-2006 11:17:49
 Re: Looking for plow leighs in reply to 55 50, 09-27-2006 11:00:30
The people who make plow parts call then Plow Shares. Shoup is one distributor of mostly modern parts. A couple makers are in Perry Iowa.
You can't tell the plow bottom parts from just the plow maker. Each maker sold plow bottoms separately from the plow frames because different soils worked better with different shapes. Some offered 20 or 30 different bottoms and parts often don't interchange between them. You will need to find part numbers on some plow bottom (which consists of a FROG that everything bolts to and which bolts to the plow frame, a moldboard, a plow share, sometimes a shin, and often a landside) part and use that to trace down which plow bottom you have, then you can maybe find plow shares to fit. Or take an old plow share off and carry it with you to the farm stores that still carry plow parts hoping to match the top and back shapes and the bolt holes.
Gerald J.
