Any body know the good, bad and ugly of these
old
09-26-2006 07:24:29
Allis MOCO not sure of the model number but its about a 9 foot cut. A NH 271 rake. A NH 55 baler and a NH67 baler. We have a deal where we will be tradeing for these and some tractors also. I'd just like to know all I can on these since I get the fun of tring to make them all work again.
Thanks
By the way this is just a short list of the stuff theres a whole lot more stuff included and I'll be asking more soon
MLD
09-28-2006 13:13:01
 Re: Any body know the good, bad and ugly of these in reply to old, 09-26-2006 07:24:29
Friend has an old Allis MOCO, worked good until a bearing went out, AC dealer can get the bearing. He couldn't get the sproket off the shaft, bent the sproket tring. "No problem", use a torch, cut the sproket off & get a new sproket & bearing...wrong!!!! Sproket not available!!! Its setting in field now for parts, he bought used GEHL for about $5000.
paul
09-26-2006 21:59:57
55 rake is the older style, good tho. Go about $3-400.
271 baler has the better hitch, otherwise exact same as a 270. Last, rock solid of their smaller line of good balers, basiclly the 69 revised several generations. Go from $250 - 1500 depending on condition.
Dyslecia is a terrible thing, isn't it. ;)
--->Paul
KEH
09-26-2006 07:37:31
Had a 67 baler which gave good service. Would make bananna bales unless windrows were large. It has wooden slides on the plunger. It is like a 68 except that the 67 has a short non swinging tongue. The area that is likely to be rusted if the baler sat outside in a damp climate is the part of the bale chute under the knotters.
How did the goat trailere work out?
KEH
old
09-26-2006 07:41:33
 Re: Any body know the good, bad and ugly of these in reply to KEH, 09-26-2006 07:37:31
Done with the trailor other then painting it. Waiting on the guy to bring me some sand for the blaster so I can snad blast it before I paint it. When done I'll post some pictures in I guess the implament area
Josh in Pa
09-26-2006 07:35:39
I think parts for the allis mower are hard to come by. The NH rake is likely a 55, older with a straight axle, not worth a ton. The balers likely a 67 and 271, 271 is a real nice smaller baler if its in good shape.
Josh
