Anyone have a 501 mower to sell parts from?
Tom in TN
09-23-2006 16:58:49
Hey Guys,
I have a Ford 501 six-foot sickle bar mower that I need a part for. It's a bar that's about 18 inches long with two tie-rod ends on it. It's called a push rod. It connects from the frame of the mower to the actuator lever on the big coil spring that controls the sickle bar. That part is not available on this site. Ford/HN wants $360.00 for it. I found a really junky mower at a used implement dealer, but he wants $300.00 for it. If I can't find the part somewhere else, I guess I'll bite the bullet and buy a new one.
Anyone have one to sell?
Thanks,
Tom in TN
Oldmax
10-02-2006 04:51:38
 Re: Anyone have a 501 mower to sell parts from? in reply to Tom in TN, 09-23-2006 16:58:49
I would find a tie rod end somewhere with some length to it cut rod and weld it on making sure to keep the right lenght . If you don't wan't to weld just cut & thread rod using a threaded coupling to connect rod & tie rod end .
Lumpy
09-23-2006 17:19:38
Do you have the old one? If so whats wrong with it? Maybe you could have a machine shop make one for you.
Tom in TN
09-23-2006 19:15:44
 Re: Anyone have a 501 mower to sell parts from? in reply to Lumpy, 09-23-2006 17:19:38
Lumpy,
I actually have a very good machine shop in Columbia, TN. I took it to them first, to see if they could do anything. Here's the problem, one of the tie-rod ends is stripped where the nut screws onto it to hold it into the actuator arm on the big spring. The ends are not replaceable like automobile tie-rods. The machinist tried to cut the threads down from the 1/2 inch that they were originally to 7/16 inch, however, the tie-rod end is very hard and he was unable to keep it from turning in its socket while he was attempting to thread it down to a smaller size.
Maybe it would be possible to buy a tie-rod end from another application and have it welded on in place of the bad one. I have no idea where to begin looking for the specifications on tie-rod ends to try to match the length, diameter, and pitch of the end.
Do you have any idea where that kind of information could be located?
Thanks for your help.
Tom in TN
old
09-23-2006 20:44:16
 Re: Anyone have a 501 mower to sell parts from? in reply to Tom in TN, 09-23-2006 19:15:44
I might haver the part you need but I'm not sure. Can you send me an e-mail of a picture of what you need. Also your about 35-40 miles from Athens right?? I have bits and pieces of an old 501 or 515 plus a manula for it if you need any thing from the manual I can scan pages also
Tom in TN
09-24-2006 07:25:28
 Re: Anyone have a 501 mower to sell parts from? in reply to old, 09-23-2006 20:44:16
Old,
Thanks for the note. I'm actually about 40 due miles south of Nashville. I don't remember for sure, but I was thinking that Athens was northeast of Chattanooga.
In any event, I'll try to scan a picture of the push rod and get it to you. In my Operator's Manual, the rod is pictured in figure 5 on page 6. It's also item #4 in figure 15 on page 18. But who knows, your manual might be different from mine.
Thanks again, and I'll try to get the pictures to you later today.
Tom in TN
old
09-24-2006 12:27:37
 Re: Anyone have a 501 mower to sell parts from? in reply to Tom in TN, 09-24-2006 07:25:28
Well if its the breakback assembly I think I have that laying out by my shop. As per figure 29 on page 23 of the manual I have for the series 515 mower which for the most part is the same as your mower
