Dearborn/Ferguson Plows
JimTN
09-23-2006 08:20:20
Need source for Dearborn plow points and other parts. I have a solid moldboard double that needs one point and the furrow wheel. Point bolts on with four bolts. Have a slat moldboard with good points and slats damaged that I need parts for. Points on it are pulled on with a ring bolt. Tags are gone off both of these.
Scott PA
09-23-2006 18:01:19
 Re: Dearborn/Ferguson Plows in reply to JimTN, 09-23-2006 08:20:20
You need to read the number on the back of the Dearborn solid moldboard or point to see if it is still made, the Dearborn screw-on furrow wheel is still made. The slat moldboards are not made anymore, you can send me an email with your numbers if you want or post here.
