NH s-68 baler plunger stuck
katenrich
09-20-2006 08:55:49
This baler broke a chain then the timing was off and broke some shear pins and feeder forks. Started smelling like burnt wood.Now we have the book to time it right but the plunger is stuck. Everything is disconnected except the plunger but you can't turn the PTO without breaking shear pins. Is this fixable? Somebody please Help!
Barry in TN
09-20-2006 18:16:38
 Re: NH s-68 baler plunger stuck in reply to katenrich, 09-20-2006 08:55:49
I just finished rebuilding a plunger on a Model 68. They are all old balers. Accumulation of rust inside the bale chamber can really challenge that plunger. It is possible that your wood "bearings" are worn out - two of mine were 90% missing. If you decide to take the plunger out the rear of the machine I can tell you how to do that.
dej(JED)
09-20-2006 09:11:03
Disconnect the plunger arm from the flywheel and hook a comealong between the tractor drawbar and the plunger. Pull it back. It has probably jambed backwards.
