shear pin protection for PTO
Charlie
09-19-2006 15:06:00
How can I get some advice on the right kind and level of shear pin protection for a PTO drive from a 40 hp tractor to a sawmill? Overriding clutches seem to protect in the other direction. My application is for a Belsaw mill. The PTO has a clutch, but I think I want separate protection. How large a pin? What kind of coupler would you recommend?
Bill (Wis)
09-19-2006 18:05:54
 Re: shear pin protection for PTO in reply to Charlie, 09-19-2006 15:06:00
Take a look at a WD or WD45 Allis sometime. Way up where the pto shaft attaches to the 90 degree drive. They use a shear pin. I've broken them . I now use a bolt from the hardware store that is designed as a wagon axle. Works good.
Nebraska Cowman
09-19-2006 16:48:23
I'm not sure that will work. I tried a tractor on a Bellsaw mill once years ago. I hooked up the driveline from a silo blower that already had shear-bolt protection built in. I "knew" I should hook up a lever so I could throw the PTO out from my position by the saw if I needed to stop the mill. But no, I was in too big a hurry to do it right. It wasn't long before I stalled the carriage and got the blade hot. I was fortunate enough to find a man who knew how to hammer tension back into the blade. But. Lesson learned. Be able to shut down your power.
Jossette
09-19-2006 15:20:10
I would try a flywheel from a junk baler.. Massey # 10 is basically by itself and all the pin protection you need...
