Vermeer 605H gate bent down..?
TimS in Mo
09-19-2006 09:02:41
Any ideas on how to straighten this? The channels on that the side of gate are bent down somewhat, and the gate seems to be an inch or so too low on that side keeping the latch from closing.
Any ideas on how to bend the channels back up without diassembling the gate? I thought about chaining down the big tube that runs across the back of the gate to the axle, heating the area that needs to bend and then applying pressure upwards with a jack or with the hydraulics....
vernMN
09-20-2006 03:32:20
 Re: Vermeer 605H gate bent down..? in reply to TimS in Mo, 09-19-2006 09:02:41
Same problem on my 605H. Did exactly as you mentioned and worked. Chain down and apply pressure and heat a little.
IaGary
09-20-2006 03:26:43
I assume it was bent by closing on something.
Soooo if you open the gate to that height at which it was bent and then chain down or secure the gate so it cannot go higher lift with the cyinder to push that bend in the lift bracket back out.
Find where the gate itself is bent and hook the hold down chain so that bend can go back up also.
If you get the lift arm straight and the gate is still bent you then may be able to jack under the gate its self to straighten it.
With using the hydraulics I would not use any heat.
I said chain down at the height it was bent but you may have to get the lift arm at 90 degrees to the cylinder for it to have leverage to straighten the lift arm.
You may want to tie down at the outer end of the lift arm itself and not the gate to start with.
Any guestions?
Gary
Doug in IL
09-19-2006 14:16:30
I don't think you have much to lose trying what you have suggested. But I think, I would remove the parts to straighten them. You could also get some new channel iron and just replace them. My 504G has a similar problem. But on mine, the upper pivot broke out of the vertical channel iron and ripped down through the steel about 8 inches. Looks like it was cut with a saw! I haven't figured out the best way to fix it either.
R. John Johnson
09-19-2006 11:18:17
Tim
That looks ugly to me. I wonder how that happened. We ran 605F balers for years and never had that kind of a bend. I caught my share of bales with the gate too. If you are going to get it back in place, it looks like heat will be needed. The only other thought is to check for a used part from a wrecker. Might be simpler in the long run.
John
