Sandrum Plow
Thomas Harvey
09-17-2006 12:42:17
I have a sandrum plow its a nice plow fully auto reset. The only problem I can see is I can find no dealer for the plow. I brought it for $350 probably why so cheap. I pull it behind my Farmall 656 it has about 20" bottoms. I have found some info from Europe and think it will take the kverneland parts? Any info would be great. I have about 300 acres to plow so bet somewhere along the line I am going to break something as we have rocks in Maine.
Tom
RodInNS
09-17-2006 17:01:37
 Re: Sandrum Plow in reply to Thomas Harvey, 09-17-2006 12:42:17
Well, I know a sum total of nothing about Sandrum plows. That said, if it has Kverneland bottoms, then any wear parts can be obtained by getting the stamped part number off of the backside of the respective part... boards, shares, landsides, shins, etc. If you can narrow that down to a body number, that should get you pretty much anything. If you can post a clear pic of the bottom, then I could be fairly certain visually whether or not it's a Kverneland, although I may not know the bottom number off hand. HTH.
Rod
Thomas Harvey
09-18-2006 02:55:40
 Re: Sandrum Plow in reply to RodInNS, 09-17-2006 17:01:37
I have been researching and using plough instead of plow I bring up some European sites and these plows are called sandrum/Fraugde and mine is a Sanderum but they are the same plow. Also I found a list of Kverneland plow parts and I found a number on mouldboard extension on my tractyor 063388 its the same number as the Kverneland plow. So any info is great and I am plugging away at what I can find.
Thanks
Tom
RodInNS
09-18-2006 07:41:26
 Re: Sandrum Plow in reply to Thomas Harvey, 09-18-2006 02:55:40
Well, if you've got the Kverneland number off the board, you can call any Kverneland dealer and they will get you the part. That is largely how Kerneland dealers handle wear parts, rather than through a parts book. Get the wear part numbers, as stamped, off the part. Good luck.
Rod
RodInNS
09-18-2006 07:46:07
 Re: Sandrum Plow in reply to RodInNS, 09-18-2006 07:41:26
BTW, for what it's worth, I would suggest using genuine Kverneland wear parts. I've used aftermarket stuff, and the Kverneland always wears the cheapest.... although it costs more the day I buy it. Can't post the name of the cheap stuff here, but if you want to know, email me. HTH.
Rod
