Need help identifying old disk
Ebbsspeed
09-16-2006 12:53:48
I put a couple of pictures in the "Help Identify" section of a disk I recently bought. It's a small 88" wide disk, and uses a wood cylinder as a bearing between the bearing housing and the disk gang separators. First of all, was this common, and second, is there anywhere that I might find these or am I better off going to work with the hole saw and making my own? The only numbers on the disk are on the bearing housings, number is H164. Thanks!
