New Holland 469
haybaker
09-13-2006 09:05:33
I need to replace the pins and springs in the overrunning clutch. I can't break the bearing free on the left end of the shaft, nor the gear on the right to create a little room to work on the clutch. I don't want to start banging on the end of this shaft, unless that's the only way to get them off. There was no collar/set screw on the left end, and I've removed the nut from the right end already. Any advice is appreciated.
Josh in Pa
09-14-2006 12:44:56
 Re: New Holland 469 in reply to haybaker, 09-13-2006 09:05:33
Newer haybines didn't have the overrunning clutch. I have seen people weld the old ones up when they go out.
Josh
jiskies
09-13-2006 17:37:10
cut off with a torch is how its been done on our 469! more than once...
jeff
paul
09-13-2006 11:09:47
I don't know for your machine exactly, but I've found if the bearing doesn't fall off in the first minute of prying, I bring the O2 torch over & get things done in 3 more minutes. By the time you pry/beat the bearing out it needs replacement anyhow, and just saves agrivation & wrecking other parts with the beating & prying.
--->Paul
haybaker
09-13-2006 11:56:00
 Re: New Holland 469 in reply to paul, 09-13-2006 11:09:47
Thanks, it should just come off there but has probably just seized on. I"m not a willing mechanic, but can"t afford to not do it myself. I"ll put some heat to it to see if it breaks free. Thanks
paul
09-13-2006 22:36:22
 Re: New Holland 469 in reply to haybaker, 09-13-2006 11:56:00
I've done maybe 20 bearings in the last 2 years, mostly the combine & the round baler, and one came off like it should..... Grrrr. ;)
Couple years ago there was one behind a split sheeve that just would not come apart. I was heating up things that shouldn't be heated to try to get it all apart. Ended up mushrooming the end of the shaft (didn't see the grease channel...) and so just pulled the whole sghaft out, off to the salvage yard for a new used one.
--->Paul
