JD 555H plow
farmallman
09-13-2006 07:53:16
I haver the oppurtunity to buy a 555H 4x14 plow. According to the owner, it has all new parts and is field ready. He wants $1600. Is this good?
James2
09-14-2006 19:22:18
 Re: JD 555H plow in reply to farmallman, 09-13-2006 07:53:16
Answering you over here rather than the JD post. Rather than the JD model 555H, I would look for a 4-5 bottom model 66H or 77H to match the model 820 you intend to get. If it is the "black dash" later version, I would go for five. The heavy duty 7 series is more difficult to find. The 555 is a little light duty for the 820. A 666 or 777 would be OK but are newer.
farmallman
09-14-2006 19:26:09
 Re: JD 555H plow in reply to James2, 09-14-2006 19:22:18
What is so special about the 'black dash' version? and what is the difference...or is only the obvious the difference
thanks
James2
09-14-2006 19:42:55
 Re: JD 555H plow in reply to farmallman, 09-14-2006 19:26:09
The early "green dash" 820 had the same engine as the 80. Late version "black dash" 820 had the same engine used in the later 830. The plate around the gauges was changed from green to black paint, thereby the nomenclature, black and green dash. The "black" has approximately 10 more hp. But, anyone could use a little paint for an easy deception, faking a S/N is a lot more difficult.
farmallman
09-14-2006 19:44:19
 Re: JD 555H plow in reply to James2, 09-14-2006 19:42:55
ok, so where was the s/n split?
James2
09-17-2006 16:02:31
 Re: JD 555H plow in reply to farmallman, 09-14-2006 19:44:19
Found it! In the beginning of the 1958 model year S/N 8203100.
James2
09-16-2006 21:44:12
Been looking thru my books, and haven't found the right one yet. It is somewhere, I'll keep looking.
Bob Collins
09-13-2006 09:22:18
By "All new parts" I suppose you mean all the wear parts for the bottoms. Does it have new tires and a hydraulic cylinder with it? Only you can decide if it is worth that much, but $1600!, I tend to agree with mjbrown. MHO
farmallman
09-13-2006 09:59:21
 Re: JD 555H plow in reply to Bob Collins, 09-13-2006 09:22:18
By all new parts, i mean new moldboards, landslides and points. I dont know about new tires, but according to the owner, the hydaulic cylinder and everything is complete and works. I never saw it personally. He also said he put new paint on it, etc. But that dont really mean a whole lot, does it?
mjbrown
09-13-2006 08:11:02
With old parts on it I think it would be about $400 plow unless there is some sort of rarety I don't know about. I recently bought a 145H 4x16 semi mount for $400 with pretty worn parts and I'm not sure it was worth it. Plows nowdays are going for close to scrap price in the 4-5 bottom size. Not that many people plowing anymore.
farmallman
09-13-2006 08:38:55
 Re: JD 555H plow in reply to mjbrown, 09-13-2006 08:11:02
I realize that not alot of ppl are plowing these days, but i also heard that JD plows are rare(r) than ones like IH, MH, etc. I would get it more for play than work (shows, competitions, etc) Plowing is also an art to do it really, really well. Thanks for your input.
