Need help / I.D. on shredder gearbox problem!
Need help / I.D
09-11-2006 21:39:35
Hey guys, I need some help for a friend.
A friend of mine at work has the shredder shown below and the receptacle in his pinion gear stripped out as well as the short communication shaft that the telescoping shaft from his PTO ties into. I don't know if this is a homemade cutter or not. It looks pretty professional built to me. If you recognize it then please post with the manufacturer.
Does anyone know who makes this gearbox and where I can find parts for it?
Below with the pictures links are links to a picture of the part that I need. The bearings press on but the surface that the larger bearing installs onto has shattered and I will need to replace this whole unit. Please help if you can!!!!! :-)
This is a front pic with the gearbox and short shaft installed but loose.
These are of the complete shredder. third party image
Here are links to more. Copy and paste to your address bar to view.
Link
Link
http://img.photobucket.com/albums/v425/EZFEED/MVC-007S-1.jpg
http://img.photobucket.com/albums/v425/EZFEED/MVC-008S-1.jpg
http://img.photobucket.com/albums/v425/EZFEED/MVC-009S-1.jpg
http://img.photobucket.com/albums/v425/EZFEED/MVC-010S-1.jpg
http://img.photobucket.com/albums/v425/EZFEED/MVC-011S-1.jpg
http://img.photobucket.com/albums/v425/EZFEED/MVC-012S.jpg
I'm sure someone here either has one or recognizes the gearbox and knows where I can find parts.
Please help if you can.
Pat
Steve in Co
09-16-2006 06:58:48
 Re: Need help / I.D. on shredder gearbox problem! in reply to Need help / I.D. on shred, 09-11-2006 21:39:35
I know nothing about the manufacturer. It looks homemade, but I buy gears and bearings all the time to build custom design machinery. You can get gears from any drive supplier in any decent size city. They will need the outside diameter and number of teeth on both gears, even if you only want to replace one. Be sure to let them know it is spiral cut. Bearings are even easier. There are dozens of bearing supply houses in every state. Look up bearings in the phone book. On each half of the bearing (cup and cone) you should find a number. That number may be different for various manufacturers, but if you don't find a brand, it is likely the counterman will recognize the format. If that doesn't work you may need to get a bearing catalog and look at what dimensions are required to specify a bearing size. I like the way Timken sets up their catalog for this. Again, there are hundreds of companies world wide making interchangeable bearings. The best part of getting parts this way is that you will not be paying the incredible markup charged by implement dealers, and the bearings will be in stock at the dealer. Gears may take a week or so. By the way, you can find a bearing supplier in the phone book. If they do not sell gears, they will know who does. In Denver I generaly go to Western Belting. Hope this helps.
Patrick Martin
09-16-2006 07:26:24
 Re: Need help / I.D. on shredder gearbox problem! in reply to Steve in Co, 09-16-2006 06:58:48
But the problem I'm having is finding this gear with the PTO splined socket built into it. This gear assembly accepts the splined PTO shaft.
Who would have that?
Also would you know where or who would sell another complete gearbox unit?
Patrick Martin
09-11-2006 22:01:49
Sorry bout that guys. I put the wrong thing for my name! :-)
