Lime Spreader
bob
02-17-2000 07:37:33
Need to know what equipment is available for a retiree to spread lime and/of flue ash. They are not any commercial spreaders in my area. Total acres is about 35. We used something called an EZ-FLOW or something like that when i was growing up in the early 50's.
george s
02-19-2000 10:27:38
 Re: Lime Spreader in reply to bob, 02-17-2000 07:37:33
Anyone ever hear of, or use a pickup mounted sand spreader, like you use to sand roads, for spreading lime? Just curious, but it would probably work,at least on pasture or hay fields.
Jeff W
02-18-2000 11:09:54
You can still pick up the kind of spreader you talking about used cheap. Mine is a J.D., I use it for fert. and lime. In my area those big spreader trucks couldn't get over our feilds. Trying to use the three point hitch type only makes a mess with lime. With the old drop type you can tell exactly where you put it, same with fert. Good luck Jeff
paul
02-18-2000 18:17:19
 Re: Re: Lime Spreader in reply to Jeff W, 02-18-2000 11:09:54
I actually have a JD Van Brunt spreader also, but I don't see any on auctions around here, all been scrapped out years ago. Go for it if the guy can find one in usable condition, works great. :)
--->Paul
Dave in Mo
02-18-2000 09:32:16
Bob, I bought an E-Z_Flow spreader last winter for $100 and it is in excellent shape. It's about 8-9 feet wide on full size implement spoked tires. It's just a drawbar pulled drop spreader that I used behind our Case VAC. Worked great for about 3 acres, of course, I only had about a ton of lime to put out so it only took 2 fillings and about an hour's time. For your 35 acres, I wouldn't do it. I think I'd rather have a dealer to that much.
paul
02-17-2000 08:43:01
Most ag coops & fertilizer dealers here in the midwest have them to rent - takes a good sized tractor to pull as they are big. I would start there, as there aren't many small units made any more. Otherwise you need to find something old at an auction sale. I don't think the 3-point spreaders work very well for lime etc., but others might have actual experience with some brands that do work for this.
--->Paul
Tim(nj)
02-18-2000 20:12:07
 Re: Re: Lime Spreader in reply to paul, 02-17-2000 08:43:01
I think it is Vicon that has a 3-pt spreader than can handle lime well. Their spreader has an agitator/force feed and that shaker tube thing on the back, if I remember correctly. I think I'll go look to see if there's a website.
