wood bearing off I.H. disc
Dave H. (CO)
09-08-2006 12:35:41
Does anyone know where I can buy a wood bearing for an old I.H. disc? (I think). The number on the bottom 1/2 of the bearing is J9955. I thought it"d might be quicker to buy them than make them.
Thanks,
David
Teddy (punchie)
09-10-2006 05:11:00
 Re: wood bearing off I.H. disc in reply to Dave H. (CO), 09-08-2006 12:35:41
We use baler twine like packing. Last about 50 hours of disking and try to grease about every 5-10 hours, and check and re twine as they loosen up.
Have A Good One !!
Teddy
Nebraska Cowman
09-09-2006 10:08:20
I have some new boxings but they aren't numbered too well. If you can give me some measurements I'll go out later and check. It's been drizzling most of the morning and I'm frying chicken for lunch. Maybe I'll take a nap later.
third party image
Dave H. (CO)
09-11-2006 12:37:03
 Re: wood bearing off I.H. disc in reply to Nebraska Cowman, 09-09-2006 10:08:20
I"ll try to get some general dimensions by tomorrow. So if I make them myself, I shoud not drill down the center of the tree grain for the shaft, I should drill across, or do I have that backwards? It looks as though they were made by drilling down the center. Thanks for any help, this is the 1st set I"ve come across.
Leroy
09-11-2006 14:42:20
 Re: wood bearing off I.H. disc in reply to Dave H. (CO), 09-11-2006 12:37:03
Down the center NOT across grain
Leroy
09-09-2006 09:39:45
All the manufactures use hard maple for the bearings as it is hard enough to hold up but it will also absorb the grease and keep on lubricating the bearing and shaft that oak or hickery or any other wood will not due anddrill the hole lengthwise of the grain, do not go crosswise of the grain as it will not hold up.. I am wondering if it has wood if it is not some other maker of the disc as I think all the IH tractor discs used steel bearings with no wood.
mjbrown
09-08-2006 17:49:50
If they look like the wood bearings in an old cultipacker I have they should be easy to make. I would use oak or hickory and make them so the weight is carried on the end grain.
amo
09-08-2006 13:36:29
HAVE YOU TRIED AN IH-CASE DEALER?
Dave H. (CO)
09-08-2006 14:35:20
 Re: wood bearing off I.H. disc in reply to amo, 09-08-2006 13:36:29
No, I figured I'd be laughed at saying they don't service stuff from 80 years ago. I suppose I could try.
IowaW9
09-09-2006 06:15:53
 Re: wood bearing off I.H. disc in reply to Dave H. (CO), 09-08-2006 14:35:20
I hate being laughed at by the parts guys.
