HYDRAULIC TOPLINKS
JM in Merit
09-07-2006 17:22:44
I am trying to find something that will let me use a standard 3X8 Cylinder as a top link on my tractor. Do they make anything that will work or do I need to buy a HYDRAULIC TOPLINKS
Checked several Cylinder I had and they were all just a little bit too wide to fit.
Thanks
JD9295
09-10-2006 13:29:24
 Re: HYDRAULIC TOPLINKS in reply to JM in Merit, 09-07-2006 17:22:44
Link
Butcher
09-09-2006 07:37:18
third party image
Just make 2 pivots for your cylinders.
paul
09-07-2006 19:52:26
There are special ends that several places sell to allow for the side to side wobble. It's a joint that pins onto your cylinder.
As well, Carter & Carter & many other places sell the top links. Some of these are better with special check valves to keep it from leaking down.
BarryfromIA
09-07-2006 18:58:07
Prince Hydraulics makes a cylinder for this job. See the web site catalog.
Ryan - WI
09-07-2006 17:55:43
Don;t forget you will need ball and socket ends too unless it is an eagle hitch or similar which doesn't move in and out. The in and out motion will cause the cylinder to bend.
