14 T john deere bailer
maze
09-05-2006 06:19:11
Hi, I have a 14 T John deere bailer the knotter is not knotting the twine some times any suggestion. thank you
old
09-05-2006 07:25:14
 Re: 14 T john deere bailer in reply to maze, 09-05-2006 06:19:11
First place to start is go to a JD dealer and buy the manual, it has a trouble shoot area in it. Theres all sorts of thing that could be causeing your problems and with out a lot more info can't even begin to guess as to how to fix it
TimS
09-05-2006 08:49:12
 Re: 14 T john deere bailer in reply to old, 09-05-2006 07:25:14
Is there a knot in either of the pieces? Or just no knot at all? Is the twine broken?
maze
09-05-2006 10:21:32
 Re: 14 T john deere bailer in reply to TimS, 09-05-2006 08:49:12
at one time there is a knot at one of the twine another time there is no knot in either twines
maze
09-05-2006 10:23:00
 Re: 14 T john deere bailer in reply to maze, 09-05-2006 10:21:32
I have the manual. but i can't figure it out why the bailer acting this way?
mjbrown
09-05-2006 17:51:30
 Re: 14 T john deere bailer in reply to maze, 09-05-2006 10:23:00
The bill hook has to turn and open and close as it turns and stop and start in the right position pointing back. It probably does or it wouldn't tie at all not just miss once in a while. They are easy to take out and make sure the parts are free to move.
If the bill hooks are working right the twine has to be where it can be picked up by the bill hook when it turns. One end is held (check the twine discs) while the plunger stuffs hay down the chute and the twine gets pulled out of the ball in the box through the needle eyes. when the measuring wheel trips the needles must get the other end up close enough to the bill hook for it to be picked up also. The needle must be adjusted to come close enough for it's end to be grabbed by the bill hook.
If the packer plates in you bale chamber are worn out hay and especially straw will spring back toward the front of the baler pulling the twine the needle carries up back away from the bill hook just enough that some times it misses like in heavy hay or springy straw. Plunger extesions are also available that make the plunger push the hay back a bit further.
Hope this helps.
BTDTGTTS
