john deere 71 flex planter
npuller
09-03-2006 18:30:52
Hi every one.going to look at a john deere 71 flex planter to buy.Is the drive sprokets togeter
on the shafts or do you take them off and swap them or just move the chain to change the speed?need to make sure iam getting all the parts.It comes with corn plates.
midalake
09-05-2006 20:31:51
 Re: john deere 71 flex planter in reply to npuller, 09-03-2006 18:30:52
The sprockets interchange. If they are not all there you can order from dealer. They are cheap I used my flex planter for the first time this spring and I love it.
d6joe
09-03-2006 20:28:35
should come with 4 or 5 sprockets per unit. you only use one on the drive, and one driven. to change rates use various sproket combonations to change the drive ratios. a bolt with a 5/8 head and a washer holds the spokets to the shafts. I think the sprockets have 9,11,14,22 teeth.
Brendon
09-04-2006 04:27:58
 Re: john deere 71 flex planter in reply to d6joe, 09-03-2006 20:28:35
The sprockets supplied with the units have 11, 14, 20, and 22 teeth. The 9 tooth sprocket was optional. When buying units, one should verify that there are at least two extra sprockets bolted inside the housing.
npuller
09-03-2006 20:33:33
thanks joe thats what i needed to know
