Info on Cub 44C deck spindle assembly appreciated
crk
09-02-2006 13:24:59
I caught a haybale rope with the deck. What got inside the middle spindle cup was easy to see since that cup comes off when the blade is removed. It wiped out the seal, spring, rubber and all. I got the top pulley and cup off but am not sure how to proceed from there. I would like to remove the outside assemblies to see what may be entwined in there. Those lower cups appear to be brazed to the shaft??? I have the jam nuts off the top but the keys are jammed and it appears the nuts welded to the pulleys are threaded. How should I proceed?
I know it would be easier with a manual but I don't have one yet. If anyone feels gracious enough to lay a few hints on me I would appreciate it. Also, I would appreciate an opinion on how freely those bearings should spin when I give the pulley a liberal twist.
Thanks
Chris
