Oliver bale thrower
Bullfiddler
09-01-2006 08:19:06
I have an Oliver 520 that I recently just got a model 19 thrower to put on it. The problem is that I didn't get the shaft and hardware to power it off of the flywheel. The prior owner said he used a hydraulic pump to power it and changed the main the drive pulley out that runs the thrower belts. My question is does anyone have any idea what rpm is recommended to power the the thrower flat belts so I can make sure I have the right size pulley if I were to put a small gas engine on it?
Rich in NY
09-02-2006 18:05:08
 Re: Oliver bale thrower in reply to Bullfiddler, 09-01-2006 08:19:06
I have a NH belt type thrower that I aquired a few years back that someone had used a small gas engine to run. Looks like an 8 hp or larger. Looks by the pulley sizes to run the thrower at half the speed of the engine. 4 inch pulley on the engine and 8 inch on the thrower. Also an extra flywheel on the engine, 10 inch diameter by half inch thick steel.No flywheel on the thrower itself. I dont know how well it works because I've never gotten around to installing it on my baler. This may be some help to you assuming it actually worked OK for the previous owner.
